Это моеГость писал(а):Ах да да да
Форум разрушает веру в бога
заговор против россии
как я забыл!!
спасибо что напомнили
Questions to Karl Welz English
- Шалтай Балтай
- Разработчик
МатрицаРеволюция
Presently we are doing regular broadcasts on a daily basis (www.tvopk.com)
and I could adjust some to Russian time - the two broadcasts on the weekend
are at 8 p.m. Russian time. They are in English or German - neeah gavaryu
Russkiyi yizijk (transcription is a bit difficult!). I certainly would help
a person who wants to broadcast in Russian language.
Вот Карл мне написал,про трансляции.
- Шалтай Балтай
- Разработчик
- Шалтай Балтай
- Разработчик
- Шалтай Балтай
- Разработчик
The answer from Karl:
The quest:
radionics itself is settings, not "frequency" - when radionics was
introduced, everything was "frequency" (1904) just as today many things are
marketed as "nanotechnology" and "quantum mechanics" - the use of which
words make me croak - I studied nuclear physics, and that atlernative use of
"quantum" has as little to do with the actual science as "frequency" with
radionics.
Abrams used a special type of a relatively primitive rheostat to hear
differences of sound when knowcking the bellies of his patients and, since
the same device was used to generate specific frequencies, he assumed
"frequencies" - which was carried on and on and on by other "alternative
folks" who have not the slightest idea of technologies.
However, based on this wrong assumption, Riffe developed a system of actual
frequencies that he "shot" into the system for healing.
Radionics settings have been labeled "rates" later by people who knew about
this, and who were well aware of paper radionics.
I do have devices with actual frequency meters - see the performer in hscti.net.
I have also another one which is not yet on the sites - just built the first
devices - it is stronger than the RAD 1000 and looks like it, it is also a
water optimizer, and there the radionics setting is also a measurable
frequency and for any frequency there are many ways of setting the three
dials. range from approximately 0.6 Hz to 450 Hz. It comes with a
complimentary precision frequency meter. Can show it on oovoo, if you call
me beforehand. - or on skype - you are set up there already. on the rad
3000, the dials are for radionics rates, not frequencies, while the knob
with the LED sets the frequency - and for this you may use the stickpad.
LED blinks in the frequency speed.
Hope this helped.
The quest:
The answer:Whether it is a possible to use output on RAD-2000 in order to measure
>the frequency of the device. This is a crucial to me, since it is really
>hard to setup the correct frequency. What is the output plug for
>Radioncs? Is this the frequency of the device? IS it possible to use a
>frequency meter for output?
radionics.
Hope this helped.
- Шалтай Балтай
- Разработчик
[15:05:20] Humpty Dumpty
Hi, Karl
Thank you for your answer,
I have put it on the forum that anybody could see,
it is here: http://mindmachine.ru/viewtopic.php?p=41150#41150
[15:08:52] … So, if I understood your correctly there is a difference between radions rates and frequencies. Let us take a sample, for instance I would like to work out my intuition (the third eye, Ajna chakra ...) So, in my understandaing the best setting would be the 13 Hz frequency. Do I understand correctly that I jave to use the stick pad in order to adjuct the rate (freq) of the device?
And further is the same way I need to deal with the rest three dials?
[16:37:14] Karl Hans Welz: stick pad for individual approach - I would set up an alpha frequency - at least to leard it, possibly a low one (somnambulistic state - such as 3.5 Hz) There are lots of proposals though, and those seem to depend on individual approaches in combination with more generalized ones. Same as astrology, which seems collective-placebo-effect-objectivity combined with some things beyond that, such as stimulation of life energy fields on this planet in statiostical conjunction with earth quakes and solar eruptions.
[16:38:49] … for training in remote viewing by method of pulling the "feeling" from the ajña chakra back into the pineal gland area, I definitely consider better between 3.5 and 7 Hz, maybe the Schumann resonance of 7.83 Hz
[16:45:21] Humpty Dumpty: I see. But what would be the best way to setup Schumann resonance of 7.83 Hz? This seems to be quite precise number, I scarcely believe it is possible to that looking at the blinking LED. Should the stick-pad to be used? Or there is a better wat to do that? Is there any way to measure the frequency using the frequency meter, in order to be sure the correct number is set?
Дальше Карл - позвонил[16:56:09] Karl Hans Welz: actually, I have devices with frequency meter. and the setting on the RAD 2400 HD is food enough - even 8 Hz is still good as far as schumann resonance (measured on the "time of rotation around the Earth" by long- and medium-radio waves, which are reflected by the stratosphere) - personally I prefer it personally, although I someway consider it an interesting figure, but I cannot see much of an impact upon life itself. I consider it a purely scientific fugure based on experimentation with this type reflected waves - measured in experimental setups after plain "calculation" without much of importance in nature itself - I have a gut feeling effect on people is much more result of collective placebo effect and as such actually of importance. As I said, I prefer it personally to all other Alpha-frequencies.
[16:56:37] … going to try video call - not sure if you have microphone or webcam.
[17:03:11] … magicofthefuture.com
[17:03:20] … www.magicofthefuture.com
Рассказал несколько интересных вещей
Я попозже постараюсь изложить (если конечно есть интерес)
Сказал что скоро будет броадкаст с Lee Bennett (чемпион европы по киокашину (или кику, я уже сам забыл)) он будет говорить про перформер, это тут. www.tvopk.com
- Шалтай Балтай
- Разработчик
Признаю был не прав - Карл отвечает по делу, дело знает и любит рассказывать о приборах. Делится как общей инфой (что касается магии) так и конкретный технических характеристик прибора. Любит все показыватьШалтай Балтай писал(а):Вообще-то пока Карл плохо отвечает
Ну вообщем в кратце.
По ходу буду дописывать, если что спрашивайте
Во-первых, то что я здесь собираюсь написать, это не то что Карл сказал, это МОЕ ЛИЧНОЕ понимание ситуации, которое сложилось полсе разговора с Карлом.
Ну я не буду рассказыавть, что дело ведет Карл и его старший сын, дочь - занимается сайтом... ну и все таке прочее...
По проборам
По поводу настроек прибора
Прибор состоит из 2-х частей
1. Оргонный генератор
2. Радионик
Есть ручка настройка "частоты" (Карл не очень любит это слово (см. выше)) оргонного генератора. Шкала. (я позже приведу пост) от 0.6 до 450 Гц. Но у разныз приборов - по разному. Она хитрая. 95 на шкале соотв. приблизительно 37 Герцам. (Если учеть нелинейность, то скорее это экспонента можно составить таблицу соотв. шкалы прибора и частоты, позже нарисую ) от 95-100 (по шкале) оно улетает в 450 Гц. Мигающая лампа - отражает реальную частоту работы оргонного герератора.
Дальше - три ручки. Это НЕ частоты. Это некие внутренние сеттинги прибора, самого радионика. Я пытался выяснить что это за сеттинги. Карл сказал, что наиболее высокие результаты дает "blind experiment" (слепой эксперимент). Они делали так. Они загадывали 6 мест в комнате. Оператор, используя ручки настраивал радионик на излучение в каком-то одном месте. Второй человек - угадывал. Как я понял результат был достаточно стабильным. Дальше Карл упомянул, что в инете можно найти таблицы, в которых написано как настраивать ручки в зависимости от тренда (нужны деньги в примеру - ставим 32, 11, 67 (это с потолка цифры, просто для примера)), Таких настроек много "на все случаи жизни". Карл сказал что по его мнению, если это и работатет, то только как плацебо. Кажды должен стараться делать настройки под себя. Если есть тренд - проще. Эти установки - не являюься критичными, кто не чувствует - прибор будут работать и без этого, просто если кто чувствует хорошо - то прибор дает возможность более точной настройки.
Я так понимаю, что дальнейшее развитие темы привелобы к афирмэйшн программам
- Шалтай Балтай
- Разработчик
РисуюШалтай Балтай писал(а):Она хитрая. 95 на шкале соотв. приблизительно 37 Герцам. (Если учеть нелинейность, то скорее это экспонента можно составить таблицу соотв. шкалы прибора и частоты, позже нарисую )
Код: Выделить всё
echo "l(37/0.6)/95" | bс -l
.04338677406747594871
таблица соотв. шкалы и частоты:
Код: Выделить всё
| Rate | Hz |
| 0 | 0,60 |
| 2 | 0,65 |
| 4 | 0,71 |
| 6 | 0,78 |
| 8 | 0,85 |
| 10 | 0,93 |
VVVVVVVVVVVVVVVV
оставляю только для истории.
типа тут уже ходили.
Общий концепт такой - если есть желание выставлять ТОЧНУЮ частоту прибора - то нужен прибор с частотомером.
Последний раз редактировалось Шалтай Балтай Ср мар 03, 2010 10:22, всего редактировалось 8 раз.
Умный
Но вот и познакомились с Карлом поближе... "Коллективное плацебо", "Это совсем не то", "Какая частота ещё?", "Да это вообще не важно", "Главное структура, а не сила", "В целом, всё это костыли", "Ну, мы там когда-то проверяли в Бразилии...", "Главное - ваше сознание, остальное всё вообще никому не нужно", "Читайте аннотацию", "Я устал повторять, мою обезьяну легче обучить" и т.д. И всё будет вертеться вокруг этого. Никакой конкретики не получите от него. Он вам будет рассказывать о чём угодно - о семье, о семинарах, об экспериментах, о рунах, но не о том, о чём спрашиваете. Пока не показывает раздражения. Но это ещё впереди, поверьте...
вот забавно, "еще один человек" ( но пишут одинаково почему-то, те же слова, тот же стиль,тот же смысл) старается убедить аудиторию в нелучших человеческих и преподавательских качествах Карла... Интересно, с чего бы это?..Умный писал(а):Но вот и познакомились с Карлом поближе... "Коллективное плацебо", "Это совсем не то", "Какая частота ещё?", "Да это вообще не важно", "Главное структура, а не сила", "В целом, всё это костыли", "Ну, мы там когда-то проверяли в Бразилии...", "Главное - ваше сознание, остальное всё вообще никому не нужно", "Читайте аннотацию", "Я устал повторять, мою обезьяну легче обучить" и т.д. И всё будет вертеться вокруг этого. Никакой конкретики не получите от него. Он вам будет рассказывать о чём угодно - о семье, о семинарах, об экспериментах, о рунах, но не о том, о чём спрашиваете. Пока не показывает раздражения. Но это ещё впереди, поверьте...
- Шалтай Балтай
- Разработчик
Не могу согласится.Умный писал(а):Он вам будет рассказывать о чём угодно - о семье, о семинарах, об экспериментах, о рунах, но не о том, о чём спрашиваете. Пока не показывает раздражения. Но это ещё впереди, поверьте...
Карл ответил на все мои вопросы.
На данный момент у меня есть понимание вещей, которое меня устраивает
А что про Ваш пост - он слишком "эмоционален"
Что конкретно Вам не ясно?
О чем Вы говорили с Карлом?
Сохранился лог разговора (то что я запостил выше)?
Что ответил Вам Карл?
Что Вас не устроило?
Больше конкретики
- Шалтай Балтай
- Разработчик
Ну это громко сказано.Dimas писал(а):Правильно ли я Вас понял, что Вы разобрались с прибором?Есть какие-либо результаты?
Сейчас понятно как оно работает, в принципе.
Конечно интересно было бы "притереться" к "трем ручкам", но это требует практики.
Последний раз редактировалось Шалтай Балтай Пн мар 01, 2010 12:43, всего редактировалось 1 раз.
Ванька-встанька
Шалтай Балтай, если мне не изменяет память, в мануале расписано воздействие частот от 0,6 до 880 Гц ( для Performer'а - отдельная линейка частот). Причем частоты эти идут с дробями. Возможно, что их тоже можно привязать?Шалтай Балтай писал(а):Есть ручка настройка "частоты" (Карл не очень любит это слово (см. выше)) оргонного генератора. Шкала. (я позже приведу пост) от 0.6 до 450 Гц
- Шалтай Балтай
- Разработчик
Для перформера там должен быть рычаг переключения. Там фиксированные частоты.Ванька-встанька писал(а):Шалтай Балтай, если мне не изменяет память, в мануале расписано воздействие частот от 0,6 до 880 Гц ( для Performer'а - отдельная линейка частот). Причем частоты эти идут с дробями. Возможно, что их тоже можно привязать?
Если Вы про таблицу, то можно конечно, но нужно опять с Карлом говорить, какие-то у них реостаты совсем не линейны и даже не экспоненциальны.
А на перформере нет выхода на частотомер?
Ванька-встанька
Не знаю, если честноШалтай Балтай писал(а):А на перформере нет выхода на частотомер?
Кстати, "родной" мануал сильно отличается от того, что выложен на сайте?
- Шалтай Балтай
- Разработчик
Он с частотомером идет: http://www.hscti.net/c_chigenerator_performer.htmlВанька-встанька писал(а):Не знаю, если честно
Ванька-встанька писал(а):3 крутилки могут образовать 1,000,000 комбинаций, пока их переберешь...
Манифест - может помочь, но 3 крутилки он не отменяетВанька-встанька писал(а):Чувствую, что без проги - Манифеста здесь не обойтись
Я не очень-то смотрел в русскийВанька-встанька писал(а):Кстати, "родной" мануал сильно отличается от того, что выложен на сайте?
Ванька-встанька
Или я уже писал или просто подумал, но те самые 3 значения можно расчитать на Power Radionics 2000, а затем выставить эти значения соответствующими крутилками на приборе - я это имел в виду, когда говорил про Манифест. А иначе - настройка превратится в перебор значений, или перебор функций: а может это логарифм, а может это экспонента...Шалтай Балтай писал(а):Манифест - может помочь, но 3 крутилки он не отменяет
Может администрация сайта пойдет Вам навстречу как 1-му покупателю и даст на время (или еще как нибудь - не знаю) попользоваться программой за отзывы (или еще как-нибудь - не знаю). А так хоть видно будет: ВЕЩЬ или "вещь в себе" этот радионик
Уже с утра договорились об этомВанька-встанька писал(а): Может администрация сайта пойдет Вам навстречу как 1-му покупателю и даст на время (или еще как нибудь - не знаю) попользоваться программой за отзывы (или еще как-нибудь - не знаю). А так хоть видно будет: ВЕЩЬ или "вещь в себе" этот радионик
Завтра передам .
- Шалтай Балтай
- Разработчик
Что есть Пауер Радионикс, тогда? не понял. Программа какая-то что ли?Ванька-встанька писал(а):Или я уже писал или просто подумал, но те самые 3 значения можно расчитать на Power Radionics 2000, а затем выставить эти значения соответствующими крутилками на приборе - я это имел в виду, когда говорил про Манифест.
Здесь математикой не возьмешь, надо учится чувствовать.Ванька-встанька писал(а):А иначе - настройка превратится в перебор значений
Вроде я ее уже покупаю, (обещали со скидкой)Ванька-встанька писал(а):Может администрация сайта пойдет Вам навстречу как 1-му покупателю и даст на время (или еще как нибудь - не знаю) попользоваться программой
Но, вообщем-то я достаточно хорошо представляю что получу.
Тут все написано: http://www.akor.cc/manuals/english/manual.pdf
Что есть ВЕЩЬ в себе? например?Ванька-встанька писал(а):ВЕЩЬ или "вещь в себе" этот радионик
Ванька-встанька
Power Radionics 2000 - программа. На нынешей (по крайней русскоязычной) версии сайта ее нет уже недели 3 (хотя проверьте, может снова появилась). Стоила она там 369 USD - я даже удивился, увидев здесь прогу за 6,200 рублей.
Применительно к нам "вещь в себе" - это радионик-прибор без соответствующего мануала и программного обеспечения(шучу, конечно): вместо того, чтобы начать работать с ним, пытаешься выяснить: что делает, как включить, как настроить, какие единицы измерения показывает шкала, и вообще, что она измеряет и т.п. А вообще, это философская категория - писать придется много, да и ни к чему это здесь.
- Шалтай Балтай
- Разработчик
Шалтай Балтай писал(а):Есть ручка настройка "частоты" (Карл не очень любит это слово (см. выше)) оргонного генератора. Шкала. (я позже приведу пост) от 0.6 до 450 Гц.
Karl
>Just thinking things through.
>What is the frequency range of orgone generator for RAD-2000?
>You have mentioned the range from 0.6Hz - 450Hz, but that would be for
>new model of RAD-1000 with frequency meter, AFAIU. I suspect for
>RAD-2000 the scale should be shorter, up to 50Hz, I suspect (according
>to the blinking LED)
>What are the exact numbers? for RAD-2000
>Thank you
at about 95 it is roughly 37 Hz (where it becomes "solid" - and the last 5
positions it jumps to about 450
Karl
