Manifestation и Astro-Dynamic программы
Генераторы биоэнергии (оргона)
Karl
1. Do I understand correctly that there should some plug from PC to Radionic? If it be so, How does it look like? Is this USB one?
2. What Radioncs devices support Manifestation™ Programs?
3. Does Manifestation™ Programs works only for Windows? What about other operation systems, Linux for instance?
4. What are the technical requirement for PC?
5. Do I understand correctly that in case I am dealing with Manifestation™ Programs I should NOT care about the dials (at the device), all the 'job' regarding the link between trend and target are performed by means of the program? Is this correct or in any way the dials are to be adjusted for better performance? If so - what would be the best way to adjust them?
Thank you
Владимир Никонов
Сообщение Владимир Никонов »
Manifestation. Энергетическая программа Power Radionics™
Astro-Dynamic Manifestation (ADM). Программа астро-динамической реализации целей
Никонов Владимир писал(а):https://mindmachine.ru/catalog/shop/manifestation/
it would appear it answers one question:
Шалтай Балтай писал(а):2. What Radioncs devices support Manifestation™ Programs?
RAD-2000 and higher, I would guess
Шалтай Балтай писал(а):1. Do I understand correctly that there should some plug from PC to Radionic? If it be so, How does it look like? Is this USB one?
It would appear it does NOT. There is a structureal link between the prog and the radionics
Шалтай Балтай писал(а):5. Do I understand correctly that in case I am dealing with Manifestation™ Programs I should NOT care about the dials (at the device), all the 'job' regarding the link between trend and target are performed by means of the program?
Nope :-)
Шалтай Балтай писал(а):3. Does Manifestation™ Programs works only for Windows? What about other operation systems, Linux for instance?
I tried to set the prog up under linux Mandriva 9.1.
Setup was successful but program started incorrectly. There were no pictures at all - and it crashed pretty soon.
I will try to use VirtualBox - that should work
Получил диск с манифистайшн
на первый взгляд выглядит впечатляюще
Дерево установки
Код: Выделить всё
/cygdrive/c/Program Files/HSCTI/Manifestation$ ls
Background Images
Images
Import-Export
Orgone Transfer
Saved Operations
Sound Files
SystemFiles
def
Магические символы
Код: Выделить всё
/cygdrive/c/Program Files/HSCTI/Manifestation/Images
9 Packs French
9 Packs German
9 Packs Italian
9 Packs New AoD
9 Packs Spanish
Abramelin
Action
AlphabetDesErfolges
ArchangelsDemonsPlanets
AstroSet
AstrologyPack
Backgrounds
Chakras
Classic Packs
Crystal Spirits
Emotions
FengShui
Kabbala
KeyofSolomon
Miscellaneous
PlanetarySquares
ShintoTalismans
Targets
Tarot
elements
feng shui
fixed stars
glyphs
gnostic
gnosticsymbols
hebrew
hebrewtalismans
houses
iching
planets
planetspirits
runes
runes reversed
signs
voodoo
Код: Выделить всё
find . -type f -name "*.jpg" | grep -c jpg
2136
Более 2000 магических символов!
долго можно разбираться :-)
Хорошо что есть Шаблоны
Шаблоны
Код: Выделить всё
/cygdrive/c/Program Files/HSCTI/Manifestation/Saved Operations/Starter Templates$ ls -al
5-Position-Starter.RAD
BusinessMoney
Creativity
Gambling
Legal
Magical
Physical
Productivity
Relationships
The Mind
other
Всего Шаблонов - 54
Вот к примеру Шаблоны для бизнеса:
Код: Выделить всё
/cygdrive/c/Program Files/HSCTI/Manifestation/Saved Operations/Starter Templates/BusinessMoney$ ls -al
Attract-Customers.RAD
Brainstorming.RAD
BusinessSuccess.RAD
Good-Management.RAD
Marketing-Success.RAD
Money-Opportunities.RAD
Negotiate-A-Deal.RAD
Вот, кстати еще манифистэйшн от другого производителя: http://www.mysticalwonders.org/radionics-software/
Ванька-встанька
Сообщение Ванька-встанька »
Шалтай Балтай писал(а):Вот, кстати еще манифистэйшн от другого производителя: http://www.mysticalwonders.org/radionics-software/
Может она и работает, но настораживает подача материала, глобальные скидки на прогу и ...много еще чего. Сайт сделан из готового конструктора опять же. Мое мнение - программа - мусор, не рабочая :)
Новик
Сообщение Новик »
Я не совсем понял но получается что прогу можно использовать отдельно от прибора?
Т.е. про это самодостаточный продукт который может довать результат?
Ванька-встанька
Новик писал(а):Я не совсем понял но получается что прогу можно использовать отдельно от прибора?
Советую прочитать внимательно
В принципе возможно, но лучше использовать 2 якоря - как говорится в английской поговорке
Новик
Сообщение Новик »
Читать то читал да только там уж больно сильно агетирую к покупке самого прибора.....
Значит можно сделать вывод что сама по себе прога не полноценный продукт.
Или там идёт взаимосвязь между человеком и прогай на компьютере через ту самую трансферную карту?
Ванька-встанька
Честно говоря, я не знаю точно как действует трансферная карта (а также: имеет ли она поля для заполнения, возможна ли ее передача другому лицу вместе с программой и т.п.). Но приобретать радионик-прибор вместе с радионик-программой все таки придется - читайте посты выше и в соседних ветках форума про радионики.
На мой взгляд, Карлу стоило бы включить их один в комплект. Тем более, что стоит эта простенькая прога как современная операционная система. Но, как говорится "хозяин-барин" - и окончательный выбор всегда остается за Вами
Я понял,что трансферная карта кладется на поле тренда,тем самым расширяя его до уровня программы,где есть наборы шаблонных трендов,составленных Карлом на основе астрологии и наборы магических символов.
Карл сказал,что можно просто брать картинки трендов из программы,получая наборы трендов,потом просто класть эти карточки на поле тренда прибора.
Ванька-встанька писал(а):Честно говоря, я не знаю точно как действует трансферная карта (а также: имеет ли она поля для заполнения, возможна ли ее передача другому лицу вместе с программой и т.п.).
Поскольку пользуюсь - отпишу
Действует очень просто
Есть сама карта (бумага) - там текст 'Life energy transfer' + номер
ТОчно такая же картинка+номер (Jpg) - на СД.
Jpg - импортируется в программу, карточка кладется на тренд радионика - вуаля связка готова. Можно запускать прогу
Последний раз редактировалось Шалтай Балтай Чт мар 04, 2010 9:34, всего редактировалось 1 раз.
Трансферная карта это картинка имеющее соответствие с одним из файлов в программе.К каждой программе индивидуальная карта.
Ванька-встанька писал(а):Но приобретать радионик-прибор вместе с радионик-программой все таки придется - читайте посты выше и в соседних ветках форума про радионики.
Это личное дело каждого.
В том что Вы говорите, кончно есть смысл.
Прога дает большие возможности, но с другой стороны Вам ее никто не навязывает, к примеру можете сделать свою прогу, или купить у сторонних разработчиков
Ванька-встанька писал(а):Тем более, что стоит эта простенькая прога как современная операционная система.
Скорее всего именно поэтому - и идет отдельно
Там еще есть супер Манифест - вообще - 500 :-)
Андрей Кабанков писал(а):К каждой программе индивидуальная карта.
Система достаточно гибкая.
Можно к примеру запустить несколько инстансов одной проги на компе с различными трендами (бизнес, магия....) и так же различнами таргетами (просто фото разных людей) - все их привязать к одному радионику, а можно и к разным.
Это понятно, если вспомноить про таких "волкодавов" как РАД-5 или АТГ-12, где одновременно работают по 5, 12 оргоно-генераторов (соотв). Можно офис "осенизировать" :)
Мммм.... да можно.
Но эффект будет слабенький. (это зависит от личностных качеств, намерение, энергетика)
Можно на бумаге написать то что хотите, - это тоже работает.
А можно бамажку и на радионик положить :-)
Интересно,если запараллелить десяток таких 12-ти оргонных генераторов на один тренд,что будет :roll:
Уже тянет к эксперементам :)
у таргета - мозх оплавится :)
Ванька-встанька
Так у него и девайсы есть ценой около USD 10,000 (по размерам напоминают микшкерский пульт для DJ-ев), но кто их купит - вот в чем вопрос. Извиняюсь за прямоту, но Карл элементарно хочет "срубить побольше бабла". Может кто-то сделает другой вывод, но у меня сложилось именно такое ощущение.
По поводу навязывания приведу простой пример с калькулятором на солнечных батареях: да - он работает на этих батареях в яркую, солнечную погоду, но в остальных случаях - извольте вставить элементы питания. Будет ли это со стороны производителя навязыванием элементов питания? И да, и нет
Я думаю спрос будет,особенно в России.Сейчас народ разберется как ручки крутить и начнут покупать.Пока останавливает в первую очередь колличество ручек,а не цена,как мне кажется.Людей в России,которые могут позволить себе купить такую штуку масса.
Ванька-встанька
:lol: Если потенциального покупателя смущает только количество ручек, то самами востребованными будут младшие модели радиоников :lol:
Сообщение Логик »
Андрей Кабанков писал(а):Пока останавливает в первую очередь колличество ручек,
Пока людей останавливает отсутствие инструкций на руском языке и общее непонимание, как работать с чудо-девайсами. И неизвестна еще эффективность приборов.
Вся надежда на бескорыстных эксперементаторов!
А с колличеством ручек разоберемся. Я сидел за микшерским пультом. Когда понимаешь общую суть процесса - количество разных ручек и ползунков, посылов-возвратов на эффекты, групп каналов, кнопок mute и solo, и т.д. не пугает.
Владимир Никонов
Применение программы для воплощения желаний
Вернуться в «Радионик приборы Карла Вельца»
